NIC-USB cycling between online and offline when setup as a LTA.
  • NIC-USB cycling between online and offline when setup as a LTA.
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
‎2018-09-11 10:10 AM
Looking at the properties of the NIC-USB in workstation the status changes from Online to offline over a 5-10 second cycle
SmartStruxure 1.5
The NIC-USB is set up as an application
In the Loytec LConfig software select the Advanced button and make sure that "Run as Service.." is selected.
  • 16666
