Monitoring an external variable outside of SmartStruxure Lite to trigger a lua script
  • Monitoring an external variable outside of SmartStruxure Lite to trigger a lua script
  • Alan_Wood
    Alan_Wood
‎2018-09-06 09:17 AM
At times it is necessary to monitor an external variable to trigger action in SmartStuxure Lite
Smart Struxure Lite
Smart Struxure
Continuum
AS
MPM
Windows 7
Windows Server 2008
Need the ability to trigger actions from an external variable to run a lua script
Use a lua script in your MPM that copies the value of ME.PG#_ENABLE.value to an Analog/binary value.
This value can then be seen from the AS or BCX through bacnet and you can have the AS or BCX do different functions depending on that value
Labels (3)
  • EcoStruxure Building Expert
  • 17042
