ModbusTCP/IP Xdriver Remote Device Status Point (aka Comms Status Point) Needs a Device ID and Modbus TCP/IP User Guide
  • ModbusTCP/IP Xdriver Remote Device Status Point (aka Comms Status Point) Needs a Device ID and Modbus TCP/IP User Guide
  • BillNeville
    BillNeville
  • Alan_Wood
    Alan_Wood
‎2018-09-11 01:04 AM
A Siemens  power meter with a Modbus TCP/IP interface will not allow setting of the Device ID - only the IP parameters. Continuum Modbus TCP/IP Xdriver Remote Device Status Point (aka Comms Point] does not work if the Device ID is set to 0.
Continuum Xdriver Modbus TCP/IP Remote Device Status Point does not work if the Device ID is set to 0.
Set the Device ID = 1 when configuring the Modbus TCP/IP Xdriver Comms Point
For more information refer to page 12 of the Modbus TCP/IP Xdriver User Guide linked here.
  • 12592
