Modbus Simulator
  • Modbus Simulator
  • RobertAndriolo
    RobertAndriolo
  • RandyDavis
    RandyDavis
  • PeterLarsen
    PeterLarsen
  • Omaelk
    Omaelk
Modbus Simulator
Spock PeterLarsen Spock
‎2022-08-01 11:01 AM
Last Updated: Picard RobertAndriolo Picard ‎2022-09-28 08:20 PM
Testing Modbus device with a Modbus simulator.
EcoStruxure Building Operation.
  • Building Operation Automation Server
  • Modbus Protocol
The field device and Modbus registers can be tested with the Modbus simulator to ensure the device is set up correctly and communication is working.
Once a device is tested with the Modbus simulator, the live Modbus device can be implemented with confidence knowing that the setup in the Server is correct.
Here you can download the Modbus Simulator
Review the following video to assist with the following:
  • Run the ModRSim application
  • Setup the simulator to display the values you need to test
  • Adjust values checking that they are updated by the polling device
  • Display the Modbus traffic and capture traffic if fault finding is needed.
[video]
  • PeterLarsen22
100% helpful (4/4)
