Microsoft Visual Studio Triggers Just-In-Time Debugging
  • Microsoft Visual Studio Triggers Just-In-Time Debugging
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
‎2018-09-10 07:55 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-26 08:55 PM
When using a Windows PC with Microsoft Visual Studio installed, an unexpected error message appears referencing Just-In-Time (JIT) Debugging. This can interrupt normal operations and confuse users unfamiliar with debugging tools.
Andover Continuum, EcoStruxure Building Operation, Satchwell BAS & Sigma, Satchwell MicroNet, TAC IA Series, TAC INET, TAC Vista
Windows Operating System
Visual Studio includes a feature called Just-In-Time Debugging, which attempts to launch the debugger when a program crashes or encounters a critical error. If enabled, this feature can interfere with other applications or workflows by prompting unexpected debug dialogs.
To disable Just-In-Time Debugging, follow these steps:
  1. Open Visual Studio.
  2. Go to the Tools menu and select Options.
  3. In the Options dialog box:
    • Expand the Debugging section.
    • Select the Just-In-Time page.
  4. In the Enable Just-In-Time debugging of these types of code box, uncheck the relevant options:
    • Managed
    • Native
    • Script
  5. Click OK to apply changes.
Note: Disabling JIT debugging modifies a registry key. You must have Administrator privileges to make this change.
Labels (8)
  • EcoStruxure Building Expert
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 8058
  • CraigEllis25
