Meter monitoring in Menta: Menta Macro
  • Meter monitoring in Menta: Menta Macro
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 11:54 AM
Last Updated: Administrator CraigEl Administrator ‎2025-08-28 11:05 PM
Need a Menta programming solution to monitor pulse signals from water, electric, or gas meters.
TAC Vista
Vista Workstation
A Menta program is required to interpret pulse signals from various utility meters.
The Menta macro provided below is configured to receive and process pulse signals from three types of meters:
  • Water meter
  • Electric meter
  • Gas meter
You can download the source file by clicking the image of the Menta macro below:
Additional Notes
  • This macro can be customized to suit different pulse rates or meter types.
  • Ensure proper signal conditioning if the pulse signal is noisy or irregular.
METERING.zip
Tags (3)
  • 11177
  • block
  • JonasBrissman25
0% helpful (0/1)
