Maximum number of backups in Vista?
  • Maximum number of backups in Vista?
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:01 AM
Last Updated: Administrator CraigEl Administrator ‎2025-04-03 05:51 PM
The maximum number of backups in Vista is 20. Is it possible to change this limit?
TAC Vista
Vista Server
When backups in Vista are set up, you can specify the maximum number of backups that should be created before the oldest is overwritten. The default is two, and the maximum is twenty.
It is not possible to change this limit as it is a hard-coded number in Vista.
Tags (2)
  • 14501
  • JonasBrissman25
