Maximum Number of Global Objects in Sigma Controllers and Integration Controllers (ICs)
  • Maximum Number of Global Objects in Sigma Controllers and Integration Controllers (ICs)
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 02:03 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 08:03 PM
What is the maximum number of global objects that can be received by a Sigma controller or Integration Controller (IC)?
Satchwell BAS & Sigma
  • Sigma UNCX96 controllers
  • Sigma UNCX32 controllers
  • Sigma Integration controllers - All types
This limitation is due to configuration and engineering constraints within the Sigma system architecture.
  • Maximum Received Globals:
    Each Sigma controller or IC can receive up to 50 global objects.
  • Transmitted Globals:
    There is no fixed limit on the number of global objects a controller or IC can transmit. However, when designing and engineering a Sigma system, it is essential to consider:
    • Controller communication load
    • System performance impact
    • Network traffic and latency
Proper planning and testing are recommended to ensure optimal system performance when transmitting a large number of global objects.
Additional Notes
  • This limitation applies only to received global objects.
  • Engineering best practices suggest minimizing unnecessary global object usage to reduce controller load and improve system reliability.
  • Satchwell BAS & Sigma
Tags (2)
  • 4738
  • CraigEllis25
