Master node in a Vista network.
  • Master node in a Vista network.
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 01:18 PM
Last Updated: Picard RobertAndriolo Picard ‎2019-09-01 09:13 PM
What is the role of the master node in a Vista network?
TAC Vista
Vista server
In a network with several nodes (Operator units), one node is designated as the Master node of the database in the network
The Master node is the node which contains the correct information about global objects.
Information about global objects is controlled by the Master node, and if the information has changed, the other nodes (Slave nodes) will copy this information when they contact the Master node. So if the master is down the slaves cannot add/delete any global objects such as users.
The other nodes will continue working normally even if the master is down.
Tags (2)
  • 6164
  • JonasBrissman19
