Manually Adding Xenta device with Group bindings in Lonmaker
  • Manually Adding Xenta device with Group bindings in Lonmaker
  • PeterLarsen
    PeterLarsen
  • Cody_Failinger
    Cody_Failinger
‎2018-09-06 03:50 PM
Can I add the group bindings manually as the option to create group binding in the System Plug-in takes time and controllers are taken offline for the period of the process
  • Lonmaker
  • Vista
This is  possible to do and works very well and effectively if you understand the process
Follow these steps to add TAG 0 system bindings and TAG 1 Xenta bindings to your new Xenta controller.
  1. In Lonmaker find the source of the TAG 0 binding buy finding any TAG 0 existing binding.
  2. Then right mouse click on the tag number and select Go to reference.
  3. This will take you to the source of the TAG 0 bindings. If a list of controllers appear then you are already at the source controller.
  4. Then Carry out a connection as normal in Lonmaker on that function block.
  5. Right click on the Virtual function block with the TAG 0 source and select the connect option.
  6. Select the TAG 0 option under the Hub tab then select the target tab and add the new Xenta controller to the system with the Add FB/SNs button.
  7. Then select the TAG 0 in the virtual function block of the new Xenta and click on the Add button. The select the OK button.
  8. This will add the TAG0 binding to the new Xenta device with the correct binding type.
  9. The next step is similar to the TAG 0 but for the TAG 1. You need to locate the TAG 1 Xenta group that you are adding the new Xenta controller into.
  10. Once you have located the TAG1 source use the same connection method as TAG0 but use the TAG1 in the virtual blocks.
  11. The final step is to download the added controller and the group master.
  • 7902
100% helpful (1/1)
