Logging into CX9900 controller using HyperTerminal
  • Logging into CX9900 controller using HyperTerminal
  • CraigEl
    CraigEl
  • AbeMeran
    AbeMeran
‎2018-09-06 02:00 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:04 PM
How to log on to CX9900 controller for commissioning or configuring IP settings.
Andover Continuum
  • HyperTerminal
  • CX9900
  • CX9940
  • CX9200
  • CX9400
First generation Continuum controllers do not support web page configuration and must be configured using a terminal emulation program such as HyperTerminal.
  1. Configure HyperTerminal for 9600 baud (or baud that matches default baud configuration for the comm port), 8 data bits, no parity, no flow control.
  2. Connect cable to comm3 (or another port configured for autoset) on controller
    (for information on cable pinout please see PinOuts for the RS-232 Connection of the older 1st Generation CX controllers)
  3. On the NetController make sure RS232 is selected, use the MODEM/RS232 override switch to de-select the modem if necessary.
  4. Run HyperTerminal and type "window" to have the controller display the log on window
  5. Default user/password is acc/acc
  • 4922
100% helpful (2/2)
