Living Space Sensor goes offline when upgrade RP-C firmware
  • Living Space Sensor goes offline when upgrade RP-C firmware
  • JonGreen
    JonGreen
  • David_Purser
    David_Purser
Picard David_Purser Picard
‎2020-06-18 01:17 PM
Last Updated: Picard RobertAndriolo Picard ‎2020-06-18 03:44 PM
Living Space Sensore goes offline after upgrading SmartX Controller firmware from 2.0x to 3.01 or later
  • Building Operation Room Controller (RPC) v3.01 or later
  • Building Operation SmartX Living Space Sensor
Living Space Sensor RJ-45 connector is plugged into Room Bus port on RPC.
Move RJ-45 connector from Room Bus port to Sensor Bus port.
  • DavidPurser20
50% helpful (1/2)
