Limitation of lines in TGML editor?
  • Limitation of lines in TGML editor?
  • Cody_Failinger
    Cody_Failinger
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:53 AM
Is there a limitation in number of lines in the TGML editor when running in source mode?
TAC Vista
  • Vista 5.1.8
  • TGML editor 5.1.8
When a graphic is opened in the editor and Source mode is chosen it is possible to see the source code for the graphic and the number of lines in the source code.
There is no known limitation on number of lines for a TGML graphic.
  • 11771
