License needed for EcoStruxure Web Services (EWS)
  • License needed for EcoStruxure Web Services (EWS)
  • David_Kendrick
    David_Kendrick
  • sesa150555
    sesa150555
‎2018-09-11 01:11 PM
Last Updated: Sisko GavinHe Sisko ‎2022-09-16 07:12 AM
Unable to see EWS objects/points under an EcoStruxure Web Services interface
  • EcoStruxure Web Services (EWS)
  • Enterprise Server
  • Automation Server
An EWS License may be needed to allow your ES/AS to use EcoStruxure Web Services
Purchase and install an EWS License if required.
Note: The EWS option is NOT required when using EWS to integrate between two Schneider Electric systems or services. Refer to PA-00349 for details.
This includes the new Smart Connector by Schneider Electric which does not require an EWS License but does require a Smart Connector License as usual
Tags (2)
  • 17419
  • DavidKendrick22
100% helpful (2/2)
