It is not possible to determine when a Continuum Security Key was removed from a Continuum Cyberstation
  • It is not possible to determine when a Continuum Security Key was removed from a Continuum Cyberstation
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
‎2018-09-06 09:13 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-11-26 01:16 PM
Is it possible to determine when a Continuum Security Key was removed from a Continuum Cyberstation?
Andover Continuum
  • Continuum Cyberstation
  • Continuum Security Key
A Security Key is removed from the Continuum Cyberstation. Being able to pinpoint when it was removed may help in investigating who has taken the key.
It is not possible to determine when the key was physically removed from the PC with the Continuum or Windows Logs.
There is no information in the Continuum Error Logs on this removal and in the Windows logs, the disconnect/connect messages for USB devices don't indicate what the device actually is.
Tags (3)
  • 17244
  • sentinel
  • workstation
