Issues installing SQL Server 2016 on Windows Server 2012R2
  • Issues installing SQL Server 2016 on Windows Server 2012R2
  • JonGreen
    JonGreen
  • Clifton_eakes
    Clifton_eakes
  • Benji
    Benji
‎2018-09-10 09:03 AM
Last Updated: Picard RobertAndriolo Picard ‎2019-09-04 04:57 PM
Receiving message that KB2919355 must be installed when installing SQL Server 2016 on Windows Server 2012R2
Andover Continuum, EcoStruxure Building Operation, TAC Vista
  • Microsoft SQL Server 2016
  • Windows Server 2012R2
To Install SQL 2016 on Windows Server 2012R2 you must have KB2919355 installed.
To install KB2919355 you must first install KB2919442.  Once this patch is installed then you will need to install KB2919355.  After this patch is installed you will need to restart the server.  After the reboot you should be able to restart the SQL server install and complete it.
Links for the required patches
Download Windows update KB2919442
Download Windows update KB2919355
Labels (3)
Tags (2)
  • 19953
  • CliftonEakes19
