Is it possible to change the displayed Event text?
  • Is it possible to change the displayed Event text?
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • AdamSteele
    AdamSteele
‎2018-09-06 07:34 AM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2022-08-21 07:26 AM
Would like to change the default Event Description displayed under Monitoring | Status Page View.
EcoStruxure Security Expert
Security Expert Server
Would like to customize Event messages by adding or removing text from the Description field for specific Events.
Unfortunately we are unable to modify any Event Description. Changing, or adding to, the event text is not an option.
A couple of alternatives could be:
  1. Add a descriptive Instruction to an Alarm that you are filtering (with an Alarm Filter) for raw data events and then monitoring the Alarms feed, instead of the Events feed, for those messages.
  2. Setup an "Action" to single out and email those specific Events that you want to see.
  • EcoStruxure Security Expert
Tags (3)
  • 19486
  • AdamSteele20
  • MahmoudSayed22
