Interfacing M-Bus meters to Modbus
  • Interfacing M-Bus meters to Modbus
‎2018-09-10 11:27 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
Interfacing M-Bus meters to Modbus.
Andover Continuum, EcoStruxure Building Operation, Field Devices, Satchwell Sigma
  • Sigma
  • IC3-Modbus
  • Mbus
  • Modbus
  • Kampstrup
  • Heat Meter
  • Multical 601
Multical 601 M-Bus meters are required to be interfaced with the BMS.
  1. A M-Bus/Modbus converter (RS-485, RS-232 or TCP) and configuration software are required. The converter  and software are available from SyxthSense or similar suppliers.
  2. Using the converter and software setup the M-Bus/Modbus system without the BMS system connected.
  3. The M-Bus/Modbus converter will automatically assign the M-Bus registers as Modbus registers. From the software note the tables and registers used.
  4. Create the Modbus registers as required for the BMS system used.
For Sigma - Create the gateway.txt, connect and configure the IC3-Modbus. A sample of the gateway.txt can be downloaded here: MultiCal Modbus Gateway.zip.
For further M-Bus information see M-Bus Protocol Information.
Labels (4)
  • Field Devices
  • Satchwell BAS & Sigma
  • 7893
