M-Bus Protocol Information
  • M-Bus Protocol Information
  • SESA116857
    SESA116857
‎2018-09-10 12:11 AM
What resources are available to get more information on the M-Bus protocol?
Andover Continuum, Field Devices, Other, Satchwell MicroNet, Satchwell Sigma, TAC IA Series, TAC INET, TAC Vista
M-Bus
The M-Bus protocol information is available on www.m-bus.com.
Select The M-Bus: A Documentation Rev 4.8
The M-Bus protocol specifications is broken down in multiple chapters.
  1. Basics of Serial Bus System
  2. Overview of the M-Bus
  3. Physical Layer
  4. Data Link Layer
Telegram Format, Meaning of Fields, Communication Process
  1. Application Layer
Structure of fixed and variable data blocks.
  1. Network Layer
  2. Appendix
Table of units, medium, data field codes, VIF extensions.
Labels (7)
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
  • 5629
0% helpful (0/2)
