Integration to CAN bus protocol
  • Integration to CAN bus protocol
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-11 04:41 AM
I/A Series R2
I/A Series G3
There is a need to integrate to devices where the available communications protocol is CAN bus.
I/A Series does not have a driver for CAN bus protocol. A third party converter / gateway can be used to convert CAN bus to a standard protocol available in I/A Series.
The following company was found after a search on the Internet. They offer solution for CAN bus to various communications protocols.
http://www.adfweb.com/home/default.asp
http://www.adfweb.com/home/about/about.asp
Note: Please note Schneider Electric do not endorse this product but provide this option as a workable solution. All support issues related to these products should be sent directly to their support centers.
  • TAC IA Series
Tags (2)
  • 13946
  • canbus
