Installing an SSL Certificate from an External Certificate Authority (CA)
  • Installing an SSL Certificate from an External Certificate Authority (CA)
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
  • David_Purser
    David_Purser
  • Jeff
    Jeff
  • Benji
    Benji
Commander JonGreen Commander
‎2019-12-05 09:52 AM
Last Updated: Picard David_Purser Picard ‎2025-11-19 01:37 PM
There is no fully detailed explanation of how to install an SSL Certificate from an External Authority (CA)
  • Building Operation Automation Server
When trying to install an SSL certificate from an external CA can fail
  1. Configure a DNS name for the AS/ES (This prevents the certificate from being locked down to a specific IP.
    1. I.E. Configure an A record for "AS_Name".com
  2. Purchase SSL Cert through a 3rd party, or use your organization's internal CA/ root CA
  3. Download and install OpenSSL or can use OpenSSL installed with EBO
  4. Run Command Prompt as an administrator
  5. Use command "cd c:\program files\OpenSSL-Win64\binOpenSSL.PNG
  6. Use OpenSSL to generate a CSR in order to obtain the certificate from the 3rd party
    1. openssl req -new -newkey rsa:2048 -nodes -keyout EcoStruxure.key -out EcoStruxure.csr
      1. Follow the prompts to fill out the information for the CSRnew key and CSR.PNG
  7. Supply CSR, other certificate contact information, and a means of validating the request to the 3rd party CA
  8. Verify identity with CA (this may not be necessary if you use your company's internal CA/ root CA
  9. Receive host and intermediate CA certificates from 3rd party CA
  10. Make sure the CRT/CER files are in the C:\Program Files\OpenSSL-Win64\bin directory of Windows Explorer
  11. Use OpenSSL to convert the CRT or CER files into PEM files, as PEM is the only format EBO will accept
    1. openssl x509 -in certFileName.cer -outform PEM -out convertedCertFileName.pemconverting cer to pem.PNG
  12. Use OpenSSL to convert the private key file generated at step 6 from .key to .prv
    1. openssl rsa -inform pem -in filename.key -out filename.prvconvert key.PNG
  13. Run WorkStation as administrator
  14. In WorkStation, Control Panel > Certificates click on the server you are trying to add the cert to, either an AS or ES.Certificates.pngmanage cert.png
  16. Put in a name for the certificate (it can be anything you'd like)
  17. Click the ellipsis next to host, intermediate, and private to add the appropriate PEM files and click ok Add cert.png
  18. Select the newly added certificate from the drop-down and save the changes to activate
  19. Warm start the server
After this process is completed, verify that connection to WebStation via HTTPS shows a secure connection/trusted certificate.
Tags (2)
  • DavidPurser22
  • JonGreen19
77% helpful (13/17)
