I/NET compatibility with EcoStruxure Building Operation 3.0.1 and higher
Select a Country
  • I/NET compatibility with EcoStruxure Building Operation 3.0.1 and higher
  • JohnBoehmer
    JohnBoehmer
  • JonGreen
    JonGreen
  • RobertAndriolo
    RobertAndriolo
JonGreen Mentor
‎2019-08-21 07:49 AM
Last Updated: RobertAndriolo Champion ‎2021-06-03 04:28 PM
  • Upgrading from EBO 2.0.x to 3.0.x causes I/NET to become incompatible.
  • After upgrading to 3.x the I/NET controllers do not come online.
EcoStruxure Building Operation, TAC INET
  • EcoStruxure Building Operation (version 3.0.1 and later)
  • I/NET Seven Software (version 2.44 and above)
I/NET Seven Software is built using a 32-bit interface. Starting with EBO 3.0.1, EcoStruxure requires the use of a 64-bit interface.
For INET seven to operate with EcoStruxure Building Operation 3.0.1 it is necessary to
obtain a 64-bit DLL from the Exchange and install it in the INET installation prior to the
upgrade.
  1. Search for INET IPortAPI64 - Software on Exchange.
  2. Download the IPortAPI64_EBO.dll.
  3. Unzip the DLL and copy the DLL to the same folder as the 32bit INET install, by default this will be C:\Program Files (x86)\INET Seven folder.
    • Note: if INET was installed in a different folder this can be found by examining the
      Windows registry key ”INETSevenPath” at HKLM\SOFTWARE\WOW6432Node\CSI -
      Control Systems International\I/Net 2000/Configurations.
  4. Install EcoStruxure Building Operation 3.0.1
  5. When the ES restarts the InetPlugIn will connect to InetIoSrv via the 64-bit IPortAPI64_EBO.dll.
Labels (2)
  • TAC INET
Tags (2)
  • JonathanGreen19
  • RobertAndriolo21
100% helpful (1/1)
