How to trigger an output with Access Denied events
  • How to trigger an output with Access Denied events
Guinan AdamSteele Guinan
‎2020-09-18 12:03 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:46 AM
Need to activate an Output when access is denied to a User at a Door.
Security Expert
EcoStruxure Security Expert
In the Door object, there is a facility for triggering Outputs on Pre Alarm, Door Left Open, and Door Forced Open but nothing for when a User is denied access.
There were new Door commands added to SP-C firmware 2.08.1018 and newer to add this functionality.
  • AccessDeniedTime = # has been added to the Door commands which will specify the duration in seconds that an output or output group will be activated for when access to the door has been denied. This must also be paired with one of the following 2 commands in order for the functionality to occur.
  • AccessDeniedOutput = # has been added to the Door commands which will specify the output that will be activated when access to the door has been denied. The # will be the database ID of the output/output group.
  • AccessDeniedOutputGroup = # has been added to the Door commands which will specify the output group that will be activated when access to the door has been denied. The # will be the database ID of the output group.
As an example, if you wanted the Output with an Id = 3 to turn on for 5 seconds when access is denied at the Door, the following lines would need to be added to the Door object in the Commands section.
  • AccessDeniedTime = 5
  • AccessDeniedOutput = 3
Door Command - Access Denied OutputDoor Command - Access Denied OutputDoor Command - Access Denied Output
  • EcoStruxure Security Expert
Tags (5)
  • Access Denied
  • AdamSteele20
  • AdamSteele23
  • Invalid Attempt
  • User Denied
100% helpful (5/5)
