How to setup a Slave Server to see only the alarms that are on the local network.
  • How to setup a Slave Server to see only the alarms that are on the local network.
  • RobertAndriolo
    RobertAndriolo
  • Chris_Asbury
    Chris_Asbury
  • DavidChild
    DavidChild
  • PeterLarsen
    PeterLarsen
‎2018-09-10 04:50 AM
Last Updated: Sisko DavidChild Sisko ‎2020-09-16 01:37 AM
When multiple Vista servers are networked up each Vista server displays all of the alarms.
TAC Vista
Vista 5 and greater
Each Vista server is set up to look and synchronize to the Master Server alarms by default.
In each node object, there is an option to send and receive alarms.
Here are the steps to stop a slave server from receiving alarms from the master.
  1. From the Master Server locate the slave node that the alarms are to be local only. The slaves' node name will look like this format.   $lan."servername"
  2. Right-click on that slave node and select properties.
  3. Uncheck the receive alarm option and select OK.
This stops that slave receiving alarms form that server. The send alarm option can be used in a similar way to stop alarms being sent to the master if required.
Tags (2)
  • 6620
  • ChrisAsbury20
