How to print out a list of I/O for each device.
  • How to print out a list of I/O for each device.
  • PeterLarsen
    PeterLarsen
  • Sacco
    Sacco
‎2018-09-06 02:23 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 07:00 PM
You need to generate a list of input/output (I/O) points for each device in a TAC Vista system for documentation, troubleshooting, or commissioning purposes.
TAC Vista
  • Menta
  • Vista Workstation
There is no direct built-in report in TAC Vista that provides a consolidated list of I/O points per device in a printable format.
To print out a list of I/O for each device in TAC Vista, follow these steps:
  1. Ensure the Vista Server is running.
    🛠️ Note: These steps must be performed on the computer where the Vista Server is installed and running.
  2. Open the System Documentation tool:
    • Navigate to the Start Menu → TAC Tools → System Documentation.
  3. Create a new I/O list:
    • In the System Documentation tool, go to the File menu.
    • Select New List → Inputs/Outputs.
  4. Select the device:
    • In the Input/Output dialog box, click Browse.
    • The Object Selection dialog box will appear.
  5. Filter and choose the device:
    • At the bottom of the Object Selection window, change the Object Type to TAC Xenta Devices (or another applicable type).
    • In the Units field, navigate through the Vista Server object tree to locate and select the desired device.
    • Click OK to confirm your selection.
  6. Generate the list:
    • Click OK again in the Input/Output dialog box to generate the I/O list for the selected device.
You can now view, save, or print the generated list for documentation or analysis purposes.
Tags (3)
  • 4115
  • PeterLarsen25
  • point
