How to move I2 controllers from one port to another on the same parent controller
  • How to move I2 controllers from one port to another on the same parent controller
  • sesa116827
    sesa116827
  • JohnBoehmer
    JohnBoehmer
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:17 PM
Cyber 1.82: 9400: Infinet commports 1 and 2: what happens if he surpasses the threshold of 127 per commport for infinet. Currently he has one commport that has 14x controllers on it. Wants to move some controllers to a different port.
Andover Continuum
Cyber Station Version 1.xx
CX9400 controller.
Various versions of I2 controllers.
Reached the max controller limitations a single comm port. of 127 per port.
  1. Get a Current Database Backup and create dmp files as needed.
  2. Go offline editing
  3. Change the serial numbers of the original controllers to a false serial number.
  4. Manually create all the Infinet controllers on the new destination commport assigning them the same or available Infinet ID as the controller that is on the original commport but a false serial number.
  5. Drag and drop copy all the points and programs from the original controller to the new controller.
  6. Verify that all the points and programs were correctly copied and are intact.
  7. Then go into the new controllers and change their serial numbers to what the serial numbers of there originating controllers were.
  8. Then move the physical infinet connection from the original commport to the new commport.
  9. Next go back to online editing. At this point you should see all your infinet controllers come back on line.
  10. Reload the controller that previously owned the Infinet controllers
  11. Reload the controller that how owns has the Infinet controller
  12. Finally reload the complete site. This last step is essential to ensure that there are not lingering handle conflicts.
It is important to note that any controllers that are referencing points in the relocated controllers will have to have these object references verified and repaired in cases where the references have been lost.
  • 4310
