How to make a listview to show Access events for a specific door.
  • How to make a listview to show Access events for a specific door.
  • GavinHe
    GavinHe
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:26 PM
Last Updated: Sisko GavinHe Sisko ‎2022-11-10 06:56 AM
Can a listview showing access events be filtered to only show access events for a specific door?
Andover Continuum
  • Cyberstation
  • WebClient
Need to monitor access events for one specific door using a listview.
  • Create an Access Event Listview (1), add filter if required (2) and set path (3) 1. Access event View.png
  • Note the full path that shows up for the door under DoorId after running the listview
The syntax of the filter string should be:
                         (DoorId is like DoorId Path String id)
Note: The filter string will not work unless  "id" is placed at the end of the qualifier.  Also the DoorId Path string must be exactly as it appears under the DoorId column for a door event of an unfiltered event listview.
Tags (2)
  • 5887
  • GavinHeward22
