How to configure the Windows Time Service to use an internal clock
  • How to configure the Windows Time Service to use an internal clock
‎2018-09-11 01:28 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:37 AM
Time synchronisation is often an issue on large BMS installations. A central time signal is normally required to make sure all controllers, terminals or workstations have the correct time. If there is no internet connection available then the time has to be synchronised from a central source.
Andover Continuum, EcoStruxure Building Operation, Satchwell MicroNet, Satchwell Sigma, TAC Vista
  • Sigma
  • Continuum
  • Vista
  • SmartStruxure
  • Windows XP
  • Windows 7
  • Server 2003
  • Server 2008 R2
Warning
No internet connection available to synchronise the system time.
Important The methods below contain steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
If using Windows XP, please use the following link - http://support.microsoft.com/kb/314054
If using Server or Windows 7 OS, please use the following link - http://support.microsoft.com/kb/816042
This has been tested for Time updates to an AS by simply using the PC IP address as the primary NTP Time Server. If the firewall is turned on you also need to make sure UDP 123 is open.
Please note that Windows will add a dispersion to the time that may cause issues with time synchronization, please see Automation Servers ignore time sync message sent from Windows NTP server that uses local internal cl... for details.
Labels (5)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (3)
  • 12680
  • as-p
  • fast
