How to configure floating control on SE7300C
  • How to configure floating control on SE7300C
  • CraigEl
    CraigEl
  • sesa346290_brid
    sesa346290_brid
‎2018-09-10 10:02 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-15 07:21 PM
User can’t configure floating application on SE7300C
EcoStruxure Building Expert
  SE7000
Can be a bad connection and misconfiguration of parameters
2 PIPES APPLICATION
4 PIPES APPLICATION
NB: Respecting mandatory configuration steps in the diagrams above will improve the solution.
Change over sensor shall be 10K type II thermistor. When water temperature goes below
74°F the system will be in cooling mode and when water temperature goes over 78°F the system will be in Heating mode.
* From the diagrams, the thermostat closes the common side of the connection.
  • EcoStruxure Building Expert
Tags (2)
  • 19732
  • actuators
