Help with Creating Custom Reports for EcoStruxure Reports Server
  • Help with Creating Custom Reports for EcoStruxure Reports Server
  • David_Kendrick
    David_Kendrick
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 10:20 AM
Last Updated: Sisko GavinHe Sisko ‎2022-10-10 03:07 AM
  • SQL
  • Report Builder 3.0
In order to create a custom report for EcoStruxure, the user must have a basic knowledge of SQL and writing SQL SELECT Statements.  Report Builder 3.0 can walk a user through most of the process but there is a bit of a learning curve.
If you are attempting to create a custom report the most difficult piece of information is determining what Tables store which information.  To get definitions of Table Rows, run the provided Database Schema report in the Web Reports browser.  This will show primary/foreign key relationships as well as give you information on what is stored in each column.
Information on Extended Trend Logs is stored in the tbLoggedEntities table and the tbLogTimeValues Tables.
Additional Metering information can be found in tbMeter, tbMeteringLogFilter, tbEntityData and tbEntityRelation
Tags (2)
  • 13453
  • DavidKendrick22
100% helpful (1/1)
