HTTP doesn't work for "Import Trend Logs" in TAC Vista Conversion Tool
  • HTTP doesn't work for "Import Trend Logs" in TAC Vista Conversion Tool
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2020-03-19 11:47 AM
Last Updated: Picard RobertAndriolo Picard ‎2020-03-19 05:29 PM
When doing an "import Trend Logs" in TAC Vista Conversion Tool only HTTPs works and not HTTP.
When using HTTP the error message below is shown:
"Log on to Building Operation server failed because Failed to access the server, a network error occurred"
TAC Vista Conversion Tool version 3.1.1
This is an issue fixed in TAC Vista Conversion Tool version 3.2.
The issue is that the "Import Trend Logs" tab looks at the HTTP/HTTPS settings of the "Convert Database" tab instead of its own.
Use TAC Vista Conversion Tool version 3.2 when available.
Workaround:
Set the HTTP/HTTPS settings on the first tab(Convert Database) even if "Import of trend logs" is done.
  • JonasBrissman20
