Get "No License available" error message when logging in to Vista webstation
  • Get "No License available" error message when logging in to Vista webstation
  • Cody_Failinger
    Cody_Failinger
  • HenrikTarpgaard
    HenrikTarpgaard
  • CraigEl
    CraigEl
  • sesa177673
    sesa177673
‎2018-09-07 11:20 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:40 PM
Get "No License available" error message when logging in to Vista webstation.
The following errors have occurred.
Please correct these errors and / or contact the system administrator.
TAC Vista
  • Windows 2008 server 64-bit
  • Vista 5.1.5
  • Vista 5.1.9
  • Evaluation License downloaded from extranet
Incorrectly formatted license setup
Check the License Setup.
Open License Setup and check the format used. The picture below shows that the license server is on the local PC (using the computer name), but this will not work.
Instead, type the file path to the evaluation license (see below).
Note: From Vista 5.1.8 and later the path should instead be C:\Program Files (x86)\Schneider Electric\License Server\taclic\licenses
If this hasn't resolved the issue try the steps outlined in TAC Vista Webstation licenses are not released after closing the Webstation browser
  • 5087
