Generating alarms in Vista from Modbus devices.
  • Generating alarms in Vista from Modbus devices.
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
  • sesa177673
    sesa177673
‎2018-09-06 01:58 PM
Last Updated: Picard RobertAndriolo Picard ‎2020-04-06 06:19 PM
  • How to generate an alarm in TAC Vista, if some event happens in Modbus units.
TAC Vista
  • TAC Vista 5.x
  • Xenta Servers
  • Xenta 511, 527, 701, 711, 721, 731 (since Vista 5.1.5), 913
It is possible to see alarms generated in Modbus devices in TAC Vista but these will not automatically create an alarm that appears in the alarm pane.
Create a change of state object that is connected to the alarm signal from the Modbus device.
If the Modbus device goes offline the value will remain at its last polled value. In this case, there may be no alarm generated so you can also monitor the online option in the Modbus device template to give an alarm that the Modbus device is offline.
Tags (2)
  • 4902
  • PeterLarsen20
