Function Block Expression limitations
  • Function Block Expression limitations
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
  • Reza
    Reza
Spock PeterLarsen Spock
‎2021-11-08 09:23 PM
Last Updated: Lt. Commander Reza Lt. Commander ‎2022-08-25 10:55 AM
No more equation characters can be entered into a Function Block application
EcoStruxure Buildings Operation
  • Buildings Operation WorkStation
  • Buildings Operations Function Block Editor
You have exceeded the maximum number of characters allowed in a Function Block expression editor.
Expression text must have less than 500 characters. Split larger equations into two Function Blocks if needed.
How to add an Expression Block
Expression Blocks
Tags (2)
  • PeterLarsen21
  • RezaAmirzadeh22
