Error message "Invalid Object Name" or "Failed to transfer application file to TAC Vista" in System Plug-In
  • Error message "Invalid Object Name" or "Failed to transfer application file to TAC Vista" in System Plug-In
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • sesa150555
    sesa150555
‎2018-09-07 02:22 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:45 PM
  • Error message "Failed to transfer application file to TAC Vista"
TAC Vista
  • LonMaker
  • NL220
  • Menta
  • TAC Vista System Plug-In
Error message "Invalid Object Name" appears when browsing in a Menta file in TAC Vista.
Add it via the System Plug-in results in an error saying "Failed to transfer application file to TAC Vista"
This could have different causes.
  • There could be a signal name that is to long (longer than 20 characters).
  • The problem can also be that there is an ALARM that have an alarm controller object defined that are using a $ (other than the default $Alr_Cntrl). TAC Vista will try to add the object and you are not allowed to add objects with $ in them.
For more help see "Update Vista database failed" Error in Vista System Plug-In.
  • 3674
