Error: The installed TAC Vista version is not compatible with XBuilder 5.1.8
  • Error: The installed TAC Vista version is not compatible with XBuilder 5.1.8
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-11 01:28 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:29 AM
Version incompatibility of Vista and Xbuilder generates an error.
TAC XBuilder
The XBuilder projects created will not be possible to use with the installed TAC Vista.
Do you want to start XBuilder?
TAC Vista
  • XBuilder versions compatible with Vista 5
  • Xenta 913
  • Xenta 527
  • Xenta 511
Incompatibility of versions when XBuilder checks installed version of Vista 5.
This error message is generated when launching XBuilder. XBuilder checks the installed version of Vista against its version and will generate an error if it is not the same. However, this is only an issue when the XBuilder is to be loaded into a Xenta Server. When using a NON-Xenta server i.e. a stand alone device that is simple passing values, this message can be ignored.
Please refer to Xenta Server firmware versus Vista Server versions for the Xenta Server compatibility matrix with Vista Server.
  • 12644
