Error: The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access.
  • Error: The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access.
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-10 08:50 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 05:33 AM
Webstation Displays the error: The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access when attempting access.
TAC Vista
  • Vista Webstation
  • ASP
  • .NET
Incorrect setting in ASP and .NET
Please run the DCOM Config 1.0.3.0.exe utility located in Helpful Vista Utilities - Configure DCOM instantly, Register ASP.NET.
  • 7781
