Error Codes: The Error Sys Var has been incremented or GLB_ELOG_DUP_START
  • Error Codes: The Error Sys Var has been incremented or GLB_ELOG_DUP_START
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
  • JohnBoehmer
    JohnBoehmer
‎2018-09-10 09:05 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:16 PM
Error Codes:
Line Level Time Stamp Error Code TCB Addr Prg Cntr Data1 Data2
1631 E 04/05/2012 10:55:30.00 0x0000640b 0x04dd8500 0x02124e26 0x00005c20 0x00000000
 Error Code Meaning: The Error Sys Var has been incremented
1632 E 04/05/2012 10:57:30.00 0x00001c0b 0x04dd8500 0x02124e26 0x0000640b 0x00000000
 Error Code Meaning: GLB_ELOG_DUP_START
Andover Continuum
Continuum Site with BCX Controllers and an Error Log
Crash of BCX and log reveals:
1629 E 04/05/2012 10:51:30.00 0x0000640b 0x04dd8500 0x02124e26 0x00005c20 0x00000000
1630 E 04/05/2012 10:53:30.00 0x0000640b 0x04dd8500 0x02124e26 0x00005c20 0x00000000
It is in the range of “Global System errors” that is usually not good, either faulty controller or need reloading of the O/S. Cold start and update O/S with the latest version supported by the Cyberstation version. Then run it on a test rig with different ID and see if it still crashes, if so will need to be repaired or replaced.
  • 7800
100% helpful (1/1)
