Error Code 80044E34 during Equalization
  • Error Code 80044E34 during Equalization
  • RobertAndriolo
    RobertAndriolo
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:08 PM
Last Updated: Picard RobertAndriolo Picard ‎2025-12-04 07:49 PM
Utilizing Equalization and an error code appears, indicating the File Master is unable to add an article (Error Code: 80044E34).
TAC I/NET
  • I/NET Seven
The file InetEqzCr.dll needs to be manually registered.
  1. Open the Windows Command Prompt (CMD).
  2. Change the directory to: C:\Program Files\Inet Seven\
  3. Run the following command: regsvr32 ineteqzcr.dll
  4. Close or exit the Command Prompt.
  5. Restart I/NET.
  6. Demote all clients and the File Master.
  7. Re-promote the File Master and then the clients.
Equalization should now work correctly.
Warning
Ensure you run the command with administrative privileges. Incorrect registration may cause system instability.
  • TAC INET
Tags (2)
  • 1898
  • RobertAndriolo25
