Equipment lead lag rotation based on runtime
  • Equipment lead lag rotation based on runtime
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-07 08:45 AM
I/A Series G3
Rotation of equipment using runtime.
A LeadLagRuntime object is available in the kitControl palette (HVAC folder).
The LeadLagRuntime object can be configured to rotate 2 to 10 loads. An explanation of the usage can be found in the Niagara Ax kitControl Guide or the online help in Workbench.
  • TAC IA Series
  • 14590
