Enrollment Reader in Access Expert
  • Enrollment Reader in Access Expert
  • Cody_Failinger
    Cody_Failinger
  • Robert_Davis
    Robert_Davis
‎2018-09-06 07:30 AM
Need to a method to automatically enroll users into Access Expert?
Access Expert
  • Premise Install
  • Hosted Instance
Enrollment readers are not used in Access Expert.
When a card is read at the Door Reader, it will result in an "Access Denied/Card Pin Not Found" event being generated. This event can then be used to create a new user. Once this user has been created and added to the system, the card will become active and have access to the doors it's assigned to.
  • EcoStruxure Access Expert
Tags (5)
  • 19768
  • automate
  • data
  • entry
  • information
