Energy Expert Compatibility Matrix
  • Energy Expert Compatibility Matrix
  • RandyDavis
    RandyDavis
  • David_Kendrick
    David_Kendrick
  • Robert_Davis
    Robert_Davis
  • DavidChild
    DavidChild
  • JonGreen
    JonGreen
Lieutenant JG Robert_Davis Lieutenant JG
‎2020-12-29 10:10 AM
Last Updated: Admiral David_Kendrick Admiral ‎2024-04-04 04:17 AM
There is a need for a single Compatibility Matrix that shows EBO, PME, Energy Expert and relevant software versions all in the same location.
EcoStruxure Building Operation, Other
  • EcoStruxure Energy Expert (formerly Power Manager)
  • ETL tool
Energy Expert version compatibility information is currently available but is stored in many different places such as release notes and online documentation, rather than one single matrix.
The full ETL for EBO compatibility matrix is shown in the following table.
Energy Expert  PME EBO ETL Integration Utility .NET Framework
Power Manager 1.0 7.2.3 1.6.1 3 1.0.14304.2 4.5
Power Manager 1.1 8 1.6.1  1.7.1 4.1 1.0.15306.1 4.5
Power Manager 1.2 8.1 1.6.1  1.7.1  1.8.1 4.3 2.1.16081.1 4.6
Power Manager 1.3 8.2 1.8.1 1.9.x  4.6 2.2.17056.2 4.6
Energy expert 2.0 9 2 5 3.0.18215.3 4.6
Energy expert 3.0 2020
3.0
3.1
6 3.1.19319.1 4.6
Not commercialized  - (n/a) 2021 3.2.3 6 Integrated - (n/a) 4.8
Not commercialised - (n/a) 2022 4.0.2/2022 6 Integrated - (n/a) 4.8
Not commercialised - (n/a) 2023 5.0/2023 6 Integrated - (n/a) 4.8
Great care must be taken when choosing the correct version of ETL to use when integrating Energy Expert and EBO, as there are actually two families of ETL in production.  One ETL designed and tested for PME use only and ETL for EBO designed and tested with an EBO Extract Task specifically for integrating the two systems.  (For example, a version of ETL 4.7 exists, but this is not ETL for EBO and therefore does NOT contain an EBO Extract Task, even though it is a valid version of ETL for the Power Community)
New
PME 2023 now offers EWS Client 1.2 which can be used to transfer data from EBO to PME instead of ETL.  The merits for and against using this new EWS Client rather than ETL are discussed at length in the PME 2023 System Guide
Tags (6)
  • DavidKendrick20
  • DavidKendrick23
  • DavidKendrick24
  • energy expert
  • PME vs EBO Compatibility Matrix
  • RobertDavis19
100% helpful (12/12)
