Enabling .NET Framework 3.5 fails using DISM fails with error 1910
  • Enabling .NET Framework 3.5 fails using DISM fails with error 1910
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • chris_clerc
    chris_clerc
  • Benji
    Benji
‎2018-09-10 10:54 AM
Last Updated: Administrator CraigEl Administrator ‎2023-09-11 01:42 AM
When attempting to enable .NET Framework 3.5 on Windows using the DISM command mentioned in the WebReport installation guide, the attempt fails with error 1910
Command: dism /online /enable-feature /featurename:NetFX3 /all /Source:e:\sources\sxs /LimitAccess
Deployment Image Servicing and Management tool
Version: 10.0.14393.0
Image Version: 10.0.14393.0
Error: 1910
The object exporter specified was not found.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log
WebReports
The Windows Modules Intaller service is not operating correctly, and has to be restarted. The service is however protected, so this can not be done through the services control panel.
  1. Kill "TrustedInstaller.exe" from the Windows task manager (CTRL+SHIFT+ESC)
  2. Start the "Windows Modules Installer" service from Windows services (Start->Run->services.msc)
  3. Try again, either using the command or the SBO Reports Preparation tool.
  • 19188
100% helpful (1/1)
