Enable Access Control.
  • Enable Access Control.
  • RobertAndriolo
    RobertAndriolo
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:26 PM
Access Control Button not visible on the Toolbar.
All versions of I/Net Software.
The check box that enables access control in the configuration editor has been unchecked.
To resolve this issue, the following steps needs to be followed:
1. Right Click on I/O Server, select the Configure link and modify the active configuration.
2. In the configuration editor, there is a radio button next to Enable Access Control.
3. Check this box, click on the Okay button, click on the make active button and close I/Net and I/O Server.
4. Restart I/Net and I/O server again, log in and the Access Button should be available now.
  • TAC INET
Tags (2)
  • 7753
  • missing
