EBO Cloud Connectivity OS requirements
  • EBO Cloud Connectivity OS requirements
  • JohnBoehmer
    JohnBoehmer
  • PeterEdvik
    PeterEdvik
  • JonGreen
    JonGreen
  • Dave_Shore
    Dave_Shore
  • Katha
    Katha
  • David_Purser
    David_Purser
Commander JonGreen Commander
‎2021-11-17 11:00 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-06 05:47 PM
Unable to connect Enterprise Server or Enterprise Central to the Building Advisor Cloud Portal
EcoStruxure Building Advisor, EcoStruxure Building Operation
  • Building Operation Building Advisor EBO Health Module
  • Building Operation Enterprise Central
There are specific Operating System (OS) requirements that must be met to ensure successful connectivity to the Azure-based Building Advisor Cloud services. Incompatible OS or software versions may result in missing trust certificates, preventing proper communication.
To ensure reliable cloud connectivity, verify that your system meets the following OS and software compatibility requirements:
Enterprise Server Software Compatibility Matrix
EBO Version Windows 10 (64-bit) Windows 11 Server 2012 R2 Server 2016 Server 2019 Server 2022 Server 2025
v3.2.4 Yes   Yes Yes Yes
v4.0 Yes v4.0.2 Yes Yes Yes Yes
v5.0 Yes Yes Yes Yes Yes Yes
v6.0 Yes Yes Yes Yes Yes Yes
v7.0 v7.0.2 Yes   Yes Yes Yes Yes
Note: Always verify the official Microsoft support status for your OS version to ensure ongoing compatibility and security.
Additional Requirements
  • Microsoft .NET Framework:
    • Required: .NET Framework 4.7.2 or later
    • Note: Versions 4.5 or 4.6 are not supported for cloud connectivity.
  • TLS 1.2 Support:
    • SmartX servers require TLS 1.2 to be enabled for secure communication with the Building Advisor Cloud.
    • Automation Servers (AS-P/AS-B) have TLS 1.2 enabled by default.
    • For Enterprise Servers running on Windows OS, ensure TLS 1.2 is enabled.
      • Refer to: How to Check if TLS1.2 is Enabled
Summary
To maintain a stable and secure connection between EBO and the Building Advisor Cloud Portal:
  • Ensure your EBO version is compatible with your Windows OS.
  • Use .NET Framework 4.7.2 or later.
  • Confirm TLS 1.2 is enabled on your system.
  • Always consult Microsoft's official documentation for the latest OS support updates.
Labels (2)
  • EcoStruxure Building Advisor
Tags (3)
  • DavidShore22
  • JonGreen21
  • KatharineVasquez25
