EBO Cloud Connectivity Network Issues
  • EBO Cloud Connectivity Network Issues
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
  • David_Purser
    David_Purser
Commander JonGreen Commander
‎2022-01-04 06:51 AM
Connection issues come in a variety of flavors, narrowing them down is important to help resolve the issue. One of the causes of connection issues could be general network problems.
EcoStruxure Building Advisor, EcoStruxure Building Operation
  • Building Operation Building Advisor EBO Health Module
  • Building Operation Enterprise Central
  • Building Operation Automation Server Premium
There are some steps that can be done to eliminate network issues as the cause of Building Advisor Cloud connectivity problems
For the ES or EC:
  1. On the server running the ES/EC, start a WireShark capture then open up the command prompt running as admin and run the following commands. Make sure to note the responses received after each command:
    1. ping app.schneider-electric.com
    2. ping cnmiothubappstna.blob.core.windows.net
    3. ping cnm-ih-na.azure-devices.net
    4. curl -X POST https://app.schneider-electric.com/ecostruxure-building-advisor/diagnostics/Initialize -k -v --header "Content-Length: 0"
  2. Open the PuTTY application and telnet to the same 3 sites you pinged above over port 443. PuTTY is installed with Device Administrator and can be found in a folder similar to: C:\Program Files (x86)\Schneider Electric EcoStruxure\Building Operation 3.2\Device Administrator\bin
If connection is successful, then you will only see PuTTY show blank black screen and it will remain without error pop-up for over 15 seconds. If unsuccessful, PuTTY will pop-up error for time out or network error, like:
 PuTTY: Network ErrorPuTTY: Network Error
For an AS-P/B:
  1. Connect to the server using Device Administrator and select the console option
  2. Run the following commands:
Curl response should look like the following (2 screenshots to show all):
Command and ResponseCommand and ResponseResponse (continued)Response (continued)
  • EcoStruxure Building Advisor
  • JonGreen22
100% helpful (2/2)
