Dual FT-10 Channel L-IP will not communicate in LonMaker
  • Dual FT-10 Channel L-IP will not communicate in LonMaker
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-07 02:42 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 11:10 PM
Unable to get a Dual FT Channel L-IP-33ECTBB to communicate after installing in LonMaker.
TAC Vista
  • LonMaker
  • Loytec L-IP
Using a "generic" router stencil in the LonMaker drawing as you would when installing a single FT channel L-IP will not work with the Dual FT Channel device. This is because of a virtual 1250 backbone internal to the Dual channel L-IP that the two FT channels hang on.
  1. To properly install a L-IP-33ECTB, use the stencil provided by Loytec.
  2. This can be downloaded via the following link: Loytec website
  3. Search for "shapes" and download the "LOYTEC Shapes Version 5.0.0" file.
Also see How to Configure Lonworks Network Interfaces to Communicate on the IP to a Loytec L-IP Router using ....
  • 3377
