Downloading New Lookup Tables to a Sigma Controller
  • Downloading New Lookup Tables to a Sigma Controller
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 02:05 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 10:13 PM
A new Lookup Table has been created. When and how should it be downloaded to the controller?
Satchwell BAS & Sigma
Satchwell Sigma
Clarification is needed on the correct sequence for downloading new Lookup Tables to ensure proper controller operation.
Follow the steps below to correctly download a new Lookup Table:
  1. Create the Lookup Table
    Use Sigma System Setup to create the new Lookup Table with the required configuration.
  2. Assign the Table to the Object
    Allocate the new Lookup Table number to the appropriate Sigma object.
  3. Download the Table
    Download the object with the assigned Lookup Table to the controller.
  4. Build and Download via Diagnostics
    • Open Sigma System Diagnostics.
    • Select the correct controller number.
    • Choose "Build and Download Lookup Table".
    This action generates a new Lookup.rec file in the OSN??? folder. The file will include the new table and any other tables required by the controller.
  • Satchwell BAS & Sigma
Tags (2)
  • 4700
  • CraigEllis25
