Does the MNB-1000-15 Remote I/O Module supports pulse inputs?
  • Does the MNB-1000-15 Remote I/O Module supports pulse inputs?
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 09:26 AM
I/A Series MNB-1000-15 Remote I/O Module
How to use the MNB-1000-15 remote I/O module universal inputs to read pulse inputs.
Standard pulse input is supported on the MNB-1000-15 universal inputs (UI1 to UI6).
Minimum Rate
1 pulse per 4 minutes
Maximum Rate
1 pulse per second
Minimum Rate
1 pulse per 4 minutes.
Maximum Rate
1 pulse per second.
  • TAC IA Series
  • 16707
