Does the M-Bus Xdriver work with the Siemens FUE950?
  • Does the M-Bus Xdriver work with the Siemens FUE950?
  • CraigEl
    CraigEl
  • BillNeville
    BillNeville
‎2018-09-10 06:32 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:47 PM
Is there an updated list of all tested devices using the M-bus Xdriver?
Xdriver
Would like to know what devices have been successfully tested with the M-bus Xdriver.
The current M-bus Xdriver Manual lists several devices that have been tested.
The question of what devices have been tested with various Xdrivers comes up now and then.
The group that develops Xdrivers is not chartered to continuously test new devices with the drivers and does not maintain a list of devices that others claim to have successfully implemented.
There are likely dozens of other M Bus devices our branches/partners have used successfully but we do not capture/verify this info.
There two best options for attempting to get this information are:
1. Ask on the Continuum Community Forum (https://community.se.com/community/bms/continuum) or
2. Obtain the product and bench test it.
  • 7815
